How can i connecting to any device and create dashboard??
Solved2.63K views19th July 2023#agent #dataminer #cube
Motoki Orikasa122 30th June 2023 0 Comments
Hey everyone,
I was able to access the Dataminer Agent using Cube.
I would like to connect to the device as soon as possible, but I don't know where to start.
Please advise.
Baptiste Pattyn [SLC] [DevOps Advocate]5.85K Posted 30th June 2023 0 Comments
Hi Motoki
to get started be sure to take a quick look at the docs. We have a lot of documentation that will allow you to get started.
I see you are looking to create an element, you can find the steps for that on this page.
If you want to create some dashboards based on the data you collected from your devices you will find information about that on this page.
Do note that there are plenty of courses available on the community website to get you started with DataMiner. I would advice you to take a look at the DataMiner Foundational training and the Visualization training for Dashboards.
Let me know if I can be of assistance to get you on your way.
You are viewing 1 out of 5 answers, click here to view all answers.
