How can I add an automation script to the catalog?
Solved1.74K views8th April 2024Automation script solution catalog
Steve Purcell [SLC] [DevOps Advocate]2.63K 5th April 2024 0 Comments
We have created an automation script to be used as a GQI Custom Operator which allows the user to select a custom property as part of the equation.  I would like to post this to the Catalog as others may find it useful but could not find how to do this.
Thanks,
Steve
Steve Purcell [SLC] [DevOps Advocate] Selected answer as best 8th April 2024
Jaime Leal [SLC] [DevOps Member]668 Posted 5th April 2024 0 Comments
Hi Steve
I think this documentation. may help you:
https://docs.dataminer.services/develop/CICD/Skyline%20Communications/Publish%20to%20Catalog/Publish_To_Catalog.html?q=catalog#publishing-automation-scripts
Regards
