Hide Spectrum settings pane be default in Visio shape.
684 views11th May 2026spectrum Visio Shape Data
7
Steve Purcell [SLC] [DevOps Advocate]2.70K 11th May 2026 0 Comments
We are working with a Spectrum Visio and have the component shape working the way we want except that the Spectrum Settings Pane always opens when the view is opened.  The user has to manually click in the ribbon to close the settings page.  Is there any way to force the settings panel closed when the view is opened?
In the final drawing there will be multiple traces present on the same page and having to close the settings panel manually would not be acceptable and require a different display solution.
I am currently using
ComponentOptions: Preset=CF1010|Measpts=5;6|ShowRibbon=true|ViewOptions=0x08
Thank you,
Steve
Steve Purcell [SLC] [DevOps Advocate] Asked question 11th May 2026
