Help with help / documantation
Solved2.23K views11th July 2023
Ken O'Connor622 23rd August 2022 0 Comments
Hello..
Can someone provide me with the Dataminer Help link regarding Alarm Groups and Alarm Suppression. I cant seem to find anything on this topic.
Jarno Lernou [SLC] [DevOps Enabler]6.08K Posted 23rd August 2022 0 Comments
Hi Ken, you might want to check the following page: Advanced analytics features in the Alarm Console | DataMiner Docs for Alarm Grouping through AI, i.e. Automatic Incident Tracking.
This DataMiner Analytics feature groups active alarms that are related to the same incident, so that the Alarm Console provides a better overview of the current issues in the system. Unlike Correlation tracking, this can happen completely automatically, without any configuration by the user. DataMiner Analytics automatically detects which alarms share a common trait and groups them as one incident.
Jarno Lernou [SLC] [DevOps Enabler] Edited answer 23rd August 2022
