Help with help / documantation
Solved2.22K views11th July 2023
Ken O'Connor622 23rd August 2022 0 Comments
Hello..
Can someone provide me with the Dataminer Help link regarding Alarm Groups and Alarm Suppression. I cant seem to find anything on this topic.
Jochen Dewachter [SLC] [DevOps Member]2.17K Posted 23rd August 2022 0 Comments
Grouping alarms can be done via correlation rules:
https://docs.dataminer.services/user-guide/Advanced_Modules/Correlation/correlation.html
Suppressing alarms can be done via masking:
https://docs.dataminer.services/user-guide/Basic_Functionality/Alarms/Working_with_alarms/Masking_and_unmasking_alarms.html
Or suppressing alarms can also be done via editing your alarm template:
https://docs.dataminer.services/user-guide/Basic_Functionality/Protocols_and_templates/Alarm_templates.html
Jarno Lernou [SLC] [DevOps Enabler]6.08K Posted 23rd August 2022 0 Comments
Hi Ken, you might want to check the following page: Advanced analytics features in the Alarm Console | DataMiner Docs for Alarm Grouping through AI, i.e. Automatic Incident Tracking.
This DataMiner Analytics feature groups active alarms that are related to the same incident, so that the Alarm Console provides a better overview of the current issues in the system. Unlike Correlation tracking, this can happen completely automatically, without any configuration by the user. DataMiner Analytics automatically detects which alarms share a common trait and groups them as one incident.
Jarno Lernou [SLC] [DevOps Enabler] Edited answer 23rd August 2022
Ken O'Connor622 Posted 23rd August 2022 1 Comment
Hi.. Thanks for your answers. Below is a screen shot of the options I require documentation on. Cant seem to find any
Jochen Dewachter [SLC] [DevOps Member] Posted new comment 23rd August 2022
Jochen Dewachter [SLC] [DevOps Member] commented 23rd August 2022
This seems to come from a specific protocol? What protocol are you using in your case?
