Having a problem in knowing where is the error.
Solved1.03K views30th September 2024
Jana Shalaby70 29th May 2024 2 Comments
Hi. I'm having a problem in identifying which ID is the one that is not unique and in the alarm its not showing, the error is (Initializing the protocol for mibswitch failed. A parameter ID is not unique. (hr = 0x80040267)).
Thank you
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 30th September 2024
Marieke Goethals [SLC] [DevOps Catalyst] commented 27th August 2024
Marieke Goethals [SLC] [DevOps Catalyst] commented 30th September 2024
Jarno Lernou [SLC] [DevOps Enabler]6.03K Posted 29th May 2024 0 Comments
Hi Jana,
Is this a connector that you have developed yourself? If so, I would suggest to use the DIS Validator tool to get to know where the issue is.
Kind Regards,
Jarno
