Have element timeout event trigger a critical alarm for the element?
Solved4.07K views16th November 2021alarm severity Correlation rule
Jeff Douglass870 12th November 2021 0 Comments
Is there a way to have an element go RED and trigger a Critical alarm for the element in timeout?
Thanks
Jeff Douglass Answered question 16th November 2021
Bert Vandenberghe [SLC] [DevOps Enabler]10.12K Posted 13th November 2021 0 Comments
Hi Jeff,
Next to using correlation, you can also simply activate monitoring of the general parameter '[Element alarm state]', and generate a critical alarm if that parameter indicates 'Timeout'.
See here below for an example together with the alarm template. Make sure to select 'All parameters (protocol + general)' in the upper right-hand corner of the alarm template editor to see those general parameters.
Ben Vandenberghe [SLC] [DevOps Advocate] Selected answer as best 13th November 2021
