Handling mapping for text input in Low code app
Solved1.12K views20th December 2024#lowcodeapp
Apurva Tandon [DevOps Advocate]1.73K 26th September 2024 2 Comments
I have a low code app where in I have 4 form fields which has 3 text input fields and last one as dropdown.
I want in each to get the data from object manager instance pre-filled if data is there, which when I try to drag drop it is not allowed on text field, how can I achieve this?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 20th December 2024
Thibault Vincke [SLC] [DevOps Advocate] commented 4th October 2024
Hi Apurva,
What is your use case exactly? If you want to make changes to a dom instance, you can do so using the form component. You can use this component to see and edit the fields of your dom instance and use a button that executes an action to save the changes. If this is what you want to achieve, seperate text inputs are not necessary.
Marieke Goethals [SLC] [DevOps Catalyst] commented 7th November 2024
Hi Apurva,
I noticed that this question has been open for some time now. Do you still need help with this, or have you found the solution in the meantime? If you still need help, could you answer Thibault’s question above? Or if you have found the solution, could you post an answer for reference for other users?
Marieke Goethals [SLC] [DevOps Catalyst]7.33K Posted 20th December 2024 0 Comments
As this question has now been inactive for a very long time, and there has been no further reaction from you, I will close it. If you still want more information about this, could you post a new question?
