Haivision: Create Source through C# / automation
Solved1.22K views22nd November 2024#automationscripts Automation haivsision
David Rid [DevOps Advocate]957 21st November 2024 0 Comments
I am attempting to create a new Source on the “Haivision Media Platform” through automation.
However, I couldn’t find a button for this functionality in the Driver; it seems to be accessible only via a right-click menu of the source table.
Is it possible to achieve this through the conventional Automation Builder?
More importantly, could you advise how this might be implemented using C#?
Best regards
David Rid [DevOps Advocate] Selected answer as best 22nd November 2024
Ive Herreman [SLC] [DevOps Enabler]14.80K Posted 21st November 2024 0 Comments
Hi David,
You can find a similar topic here and here.
The topics contain some sample code on triggering a context menu parameter from an automation script.
