GX2 Optical Level – Motorola GX2-CM100 B
Solved1.86K views28th September 2023
Ricaurte Alvarado248 28th August 2023 0 Comments
Hello Team,
We want to know the formula or the calculate to get the optical level from GX2 Optical platform from the Driver Motorola GX2-CM100 B we know that Dataminer use this OIDs (1.3.6.1.4.1.1166.6.1.2.15.2.1.8 and 1.3.6.1.4.1.1166.6.1.2.15.2.1.19) to get the value but we dont know how dataminer convert the output in dBm values.
Best,
Ricaurte Alvarado Answered question 28th September 2023
Arturo Lizcano [SLC] [DevOps Member]469 Posted 30th August 2023 1 Comment
Hi Ricaurte,
Looking at the description for that OID inside the MIB, it says that this value is “Float” type and that is represented as “IEEE 32-bit number”.
What that means is that the Dataminer connector receives a bit array that needs to be transformed to a double for it to be displayed in the connector.
I will use DIS (Dataminer Integration Studio) from now on.
After opening the connector with it, I couldn’t see any additional formatting or transformation.
In case you want to see the complete algorithm, follow these steps:
  1. Install Visual Studio 2022 (community will work)
  2. Download the Dataminer Integration Studio, from this link: Expert Hub – DataMiner Integration Studio – DataMiner Dojo
  3. Install it and register with your Dojo Account.
  4. Once it is open, go to settings>DMA, and add one (or several) of the DMA that you have deployed.
  5. In Visual Studio, go to Extensions > DIS > DMA > Connect > DMA_Name
  6. When the success message appears, go to: Extensions > DIS > DMA > Import Protocol, select the one you need and wait for it to be displayed on the main Visual Studio window.
  7. Go to QAction 3, and you’ll find the method that does the transformation.
In case of any doubts regarding the connector structure, you can refer to the online courses here:
  • SNMP connector: DataMiner Connector Integration: SNMP Basics – DataMiner Dojo
  • DIS: DataMiner Integration Studio – DataMiner Dojo
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 4th September 2023
Ricaurte Alvarado commented 1st September 2023
Hi Arturo,
Thanks for the info and guide, we’ll try this way to find the convertion method
Best,
Ricaurte Alvarado248 Posted 28th September 2023 0 Comments
Hello Arturo,
We found the method with the Software Visual Studio, but now we have more questions about the functions that use the case(62000) in QA3. Where can we find the function Calculations.CalculatedConvertedValue
oswPrimaryInputLevel[i] = Calculations.CalculateConvertedValue(Convert.ToString(((object[])oswColumns[1])[i])); // Primary Optical Analog Input Level
oswSecondaryInputLevel[i] = Calculations.CalculateConvertedValue(Convert.ToString(((object[])oswColumns[2])[i])); // Secondary Optical Analog Input Level
Best,
