Guidance on correctly configuring Primary/Secondady HTTP Connections on an element (MWCore)
Solved2.57K views14th July 2023http connection HTTP connections MWCore Virtual driver virtual element
8
Wil Helps [DevOps Advocate]20 10th May 2022 0 Comments
Hello Dojo Fans!
Seeking some guidance on correctly configuring Primary/Secondary HTTP Connections on an element, in this case specifically for MWCore.
Within MWCore configuration we have added a primary and secondary HTTP connection.  Purposely typo’d the primary connection host address (-lonzz instead of -lon), to simulate a down MWCore server:
In this configuration, we see the timeout of lonzz, but do not see any failover occurring to the secondary host URL for MWCore.  Bookings automation fails, etc.  I am expecting DM to utilise the secondary (good) connection instead.
We have reverted the typo for now;  however, could anyone please advise if I am using this feature correctly, as per the config I tested with?  Am I missing something, or should it be configured differently, or is it not working as expected?
Many Thanks!
Rene De Posada [SLC] [DevOps Advocate]1.95K Posted 11th May 2022 1 Comment
Wil,
Redundant connections are leveraged as described here: Redundant polling | DataMiner Docs
Other useful sources are:
  • PortSettings element | DataMiner Docs
  • Type element | DataMiner Docs
  • Session element | DataMiner Docs
Wil Helps commented 11th May 2022
Thank you Rene, appreciate the help and guidance!
Regards,
Wil.
