GQI filter on multi-DomInstanceFieldDescriptor
Solved1.74K views9th March 2023GQI lowcodeapps
6
Ive Herreman [SLC] [DevOps Enabler]14.79K 2nd March 2023 0 Comments
Hi DoJo,
Is there a way that I could filter a list of DOM instances based on a match in a multi-DomInstanceFieldDescriptor field?
e.g. instances A and B have a link to an instance X.
I'd like to use the ID of instance X to filter out A & B.
Ive Herreman [SLC] [DevOps Enabler] Selected answer as best 9th March 2023
Thomas Ghysbrecht [SLC] [DevOps Enabler]5.79K Posted 2nd March 2023 0 Comments
Hi Ive,
If the reference to the DomInstance is stored in a list, it is unfortunately not possible at the moment with GQI because it does not support filtering & displaying DOM fields with multiple values yet. Support should be coming in the future though, so stay tuned.
Thomas Ghysbrecht [SLC] [DevOps Enabler] Answered question 2nd March 2023
