GQI error: missing required argument
Solved506 views20th February 2026GQI GQI Data Source GQI Input Arguments GQI queries GQIDS
Daniel Mainha [DevOps Member]236 16th September 2025 0 Comments
Is there any way to avoid this error that comes prior from someone selects the necessary table row that is going to feed the query used in data source? thanks
Ive Herreman [SLC] [DevOps Enabler]14.55K Posted 16th September 2025 1 Comment
Hi Daniel,
You can solve this by setting the IsRequired bool for your GQIStringArgument to false.
e.g.
private readonly GQIStringArgument _myArgument = new GQIStringArgument("My ID") { IsRequired = false };
Do note that you'll have to handle the empty input argument further down in your ad-hoc data source, and make sure you don't depend on it and return an empty set of rows in your GetNextPage method.
Daniel Mainha [DevOps Member] commented 17th September 2025
Hi Ive,
It worked! Handled the case where the input argument comes empty.
Thanks
