GQI – Does a query gets executed for each component?
Solved1.32K views14th January 2025GQI queries
Jens Vandewalle [SLC] [DevOps Advocate]10.09K 14th January 2025 0 Comments
I have a page on which 2 different components are linked to the same GQI query. Both components are using different columns of that query. I'm wondering when loading the page if the query is executed only once or 2 times?
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 14th January 2025
Wout Mahieu [SLC] [DevOps Catalyst]12.45K Posted 14th January 2025 2 Comments
Hi Jens,
Components that are using the exact same query will only execute the query once if they request data at the same time. When one of the components would request its data at a later time, eg when outside of the initial view and becoming visible, the query is executed again.
Jens Vandewalle [SLC] [DevOps Advocate] commented 14th January 2025
Hi Wout, what when we fetch the data again for component 1 because a change happened. Will component 2 also be updated in the backend? Or do we need to execute the fetch data action for that component separately?
Wout Mahieu [SLC] [DevOps Catalyst] commented 14th January 2025
The second component will not be updated when executing a 'Fetch data' action for the first component.
