Get Resources in Maintenance Mode
Solved2.89K views5th April 2021
Julio Riambau [SLC] [DevOps Member]302 2nd April 2021 0 Comments
I'm writing a script that would list the resources in maintenance mode.
Using the GetResources from ResourceManagerHelper will get a list of the available resources.
The SLNet call GetResourceMessage will show the resource in Maintenance.
Is there a method to list the resources in maintenance from the helper or should the SLNet be used?
Thanks in advance.
Julio Riambau [SLC] [DevOps Member] Selected answer as best 5th April 2021
Jorge Dias [SLC] [DevOps Enabler]5.36K Posted 5th April 2021 0 Comments
Hi Julio,
First of all, please do never use raw SLNet messages to deal with SRM objects. There are proper managers to use, like ResourceManagerHelper, ServiceManagerHelper, etc.
As for your question, check the code below:
var resourceManager = new ResourceManagerHelper(engine.SendSLNetSingleResponseMessage);
var filter = ResourceExposers.Mode.Equal((int)ResourceMode.Maintenance);
var resources = resourceManager.GetResources(filter);
foreach (var resource in resources)
engine.GenerateInformation("Resource: " + resource.Name);
