Generic Ping Protocol not permitting Admin state toggles
Solved1.44K views14th July 2023Generic Ping jitter ping ping manager toggles not responding
Richard Turner2 5th July 2022 0 Comments
I have a Generic Ping instance configured with perhaps 15-20 pings.
All have standard ping admin status enabled.  Pings are working fine.
5 of the pings have "jitter ping" admin enabled, and are pinging fine.
For some reason, even from the default primary system user account, the Jitter Ping Admin State toggles are not responding.
Anyone got a possible reason why that might be?
Thanks,
Richard Turner
Marlies Vandenberghe [SLC] [DevOps Member]2.98K Posted 25th November 2022 0 Comments
Hi Richard,
this seems to be a bug in the driver, there is an open task where we will look into improving the error logging and/or immediately fix the root cause
