generate URL based on DCF for an element on LCA
Solved1.32K views28th August 2025LCA
Marco Di Blasi526 17th January 2025 2 Comments
Hi all
For a project I need to provide a URL in a LCA that will bring the user to an adhoc monitoring instrument.
This URL need to be generated runtime based on the devices the use inspect in the LCA,
On Dataminer I used the DCF to link each devices can be inspected in the LCA to know which is the instrument to reach out via URL.
My idea was to use an automation script to intake the info I need to generate the URL, but my question is, how I can pass the URL as script output to a widget on the LCA like a button? so the user will see the button used?
Or in case if is possible to invoke the automation script from table in the LCA, and keep the URL inside the table self?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th August 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 26th June 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th August 2025
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 22nd January 2025 0 Comments
Hi Marco,
The output from an automation script doesn't directly support this. However, we've added a follow-up item to our backlog.
As an alternative, you can create an ad-hoc data source that returns a single row containing the URL. This can be displayed in a grid as a button, allowing users to click it to open the URL.
