Freeze Titles and Parameter Headers in Dashboard Components
501 views4 days ago
Matt Murphy154 27th October 2025 1 Comment
Is there any way to force Components in Dataminer Dashboards to lock their title and parameter headers, similar to the way you can Freeze Panes in a common spreadsheet app? I have some elements on a dashboard that require vertical scrolling in the element to see everything in the table and when a user scrolls down, the Title and Parameter Headers disappear off the top of the list. I'm getting this behavior using Pivot Tables and Alarm Tables.
Marieke Goethals [SLC] [DevOps Catalyst] Posted new comment 4 days ago
Marieke Goethals [SLC] [DevOps Catalyst] commented 4 days ago
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.48K Posted 28th October 2025 0 Comments
Hi Matt,
At the moment, it’s not possible to lock the header of a table.
If you’d like, you can suggest this as a new feature here: https://community.dataminer.services/feature-suggestions/. If there’s enough interest from the community, we’ll consider adding it in a future update.
Sebastiaan Dumoulein [SLC] [DevOps Enabler] Answered question 28th October 2025
