format for TLS 1.2 and ‘useSSL’
Solved2.29K views22nd November 2022
Arunkrishna Shreeder [SLC] [DevOps Enabler]4.28K 17th November 2020 0 Comments
Hi Dojo, is this the correct way to specify TLS 1.2 in the <ConnectString> tag of db.xml ?
Also, what is the format to specify other connection keywords such as 'useSSL' ?
Thanks in advance.
Arunkrishna Shreeder [SLC] [DevOps Enabler] Selected answer as best 22nd November 2022
Miguel Obregon [SLC] [DevOps Catalyst]22.39K Posted 9th February 2021 0 Comments
An update about this topic. After further investigation we found that DMA version 10.0.0.0 uses an SLDatabase.dll which was built with .NET4.5. TLS1.2 is only supported as of 4.5.2, therefore it will not work.
A fix for this issue will be available:
  • Main release: 10.1.0
  • Feature release: 10.0.6.0-9101
Reference: DCP146754
