Filter node-edge dashboard component using a service context
Solved3.36K views26th January 2021Dashboards node-edge
Ive Herreman [SLC] [DevOps Enabler]14.79K 26th January 2021 0 Comments
The node-edge component in the dashboards is very powerful to show me my network topology and the linked KPIs.
Is it possible to filter this topology using a service i.e. only show nodes that are present in a service?
Ive Herreman [SLC] [DevOps Enabler] Selected answer as best 26th January 2021
Miguel Obregon [SLC] [DevOps Catalyst]23.67K Posted 26th January 2021 0 Comments
Hi Ive,
As far as I know, at this moment this is not possible. We have a similar use case where we need to represent (in Node-Edge) a node that represents a group of elements. In this case we are able to group these elements and display them as a node using element properties. Elements that have the same element property value will be grouped and displayed as a node.
However, I do believe that this will be a nice feature that can be added to Node-Edge.
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 26th January 2021
