Filter for information Events using parameter description
420 views10th September 2026
6
Juan Falcon [DevOps Member]400 10th September 2026 0 Comments
Hello Dojo
Im trying to filter in console information events for "Script added" type in parameter description but the filter only accept parameter descripcion by element or by protocol that works for alarms but it cant be used for information events, there is a by to make the filter?
Regards
Juan
Debeuf Klaas [SLC] [DevOps Member] Answered question 10th September 2026
Debeuf Klaas [SLC] [DevOps Member]2.06K Posted 10th September 2026 0 Comments
Hi Juan,
You can filter on on parameter description by protocol and filter on DataMiner Element Control Protocol, here you can find the script added and other parameters linked to DataMiner.
Regards,
Debeuf Klaas [SLC] [DevOps Member] Edited answer 10th September 2026
