Filenames for attachments in automation scripts
Solved1.44K views18th April 2025SMTP
edward.smith@fox.com Smith200 7th November 2024 0 Comments
When sending a report via email from an automation script, the filename is always Report.pdf.  Is there a way to name the file something unique to the report?
Michiel Vanthuyne [SLC] [DevOps Advocate]4.82K Posted 8th November 2024 0 Comments
Hi Edward, in the MailReportOptions you can set the ReportName property to the name you want to use. See Class MailReportOptions | DataMiner Docs
