Fetch alarms from Saved filters from dataminer using Automation script
Solved2.32K views26th June 2025alarm filter Automation script DataMiner Cube
Baranisudha Murugesan [DevOps Member]1.19K 28th January 2025 2 Comments
I have saved a filter to get only the alarms that i want to see in dataminer cube. Im trying to fetch the alarms that are part of that alarm filter through automation script. Is there a way to get it?
Miguel Obregon [SLC] [DevOps Catalyst] commented 28th January 2025
Hi Baranisudha,
Small question, what will be the outcome for your automation script?
Once you process the filtered alarms, are you planning to generate a report, execute an action?
Baranisudha Murugesan [DevOps Member] commented 28th January 2025
Once i get hold of the filtered alarms im displaying it in table in low code app for monitoring purpose
Matthias Declerck [SLC] [DevOps Advocate]3.14K Posted 28th January 2025 2 Comments
Hi Baranisudha,
I created some pseudo code; I do kindly want to ask to be careful with the code as it could impact your system. Why? such request call will be processed in the DataMiner system and the outcome could be that quite some data is transmitted between the processes, such as thousands or ten thousands of alarms, which is a scenario that nobody wants.
Working with repositories:
    try
        var alarmFilterKey = "MyFilter";
        var getAlarmFilterReq = new GetAlarmFilterMessage { Key = alarmFilterKey };
        var getAlarmFilterResponse = engine.SendSLNetSingleResponseMessage(getAlarmFilterReq) as GetAlarmFilterResponse;
        if (getAlarmFilterResponse?.Filter is AlarmFilter alarmFilter)
            var endTime = DateTime.Now;
            var beginTime = endTime.AddDays(-1);
            var alarmRepo = SLDataGateway.API.Repositories.Registry.DatabaseRepositoryRegistryBuilder.Default.WithConnection(engine.SLNetRaw).Build().Get<SLDataGateway.API.Types.Repositories.IAlarmRepository>();
            var alarmsFromDB = alarmRepo.Read(alarmFilter, beginTime, endTime).OfType<AlarmEventMessage>().ToArray();
            foreach (var alarm in alarmsFromDB)
    catch (ScriptAbortException e)
        engine.GenerateInformation(e.ToString());
        throw;
    catch (Exception ex)
        engine.GenerateInformation(ex.ToString());
Working with raw messages:
    try
            var getAlarmsReq = new GetAlarmDetailsFromDbMessage(dataMinerID: -1, filter: alarmFilter,
                startTime: beginTime, endTime: endTime, alarmTable: true, infoTable: false);
            var getAlarmsResponse = engine.SendSLNetMessage(getAlarmsReq) as DMSMessage[];
            if (getAlarmsResponse?.Length > 0)
                foreach (var alarmResponse in getAlarmsResponse)
                    if (alarmResponse is AlarmEventMessage alarm)
        throw;
Hope this helps you further
UPDATE: Added second pseudo code
Matthias Declerck [SLC] [DevOps Advocate] Edited answer 29th January 2025
Baranisudha Murugesan [DevOps Member] commented 29th January 2025
if i use GetAlarmDetailsFromDbMessage to get filtered alarms, im getting more alarms which are not actually present in my cluster. It is returning double the count.
Matthias Declerck [SLC] [DevOps Advocate] commented 29th January 2025
Hi, I don't exactly know what your use case is; so try to play around with options such as setting the ALarmtable option to false and verify if alarms are distinct.
Instead of using messages, you can also use repositories in order to get alarms.
I have updated original answer with also pseudo code.
