Fetch alarms from Saved filters from dataminer using Automation script
Solved2.52K views26th June 2025alarm filter Automation script DataMiner Cube
Baranisudha Murugesan [DevOps Member]1.19K 28th January 2025 2 Comments
I have saved a filter to get only the alarms that i want to see in dataminer cube. Im trying to fetch the alarms that are part of that alarm filter through automation script. Is there a way to get it?
Miguel Obregon [SLC] [DevOps Catalyst] commented 28th January 2025
Hi Baranisudha,
Small question, what will be the outcome for your automation script?
Once you process the filtered alarms, are you planning to generate a report, execute an action?
Baranisudha Murugesan [DevOps Member] commented 28th January 2025
Once i get hold of the filtered alarms im displaying it in table in low code app for monitoring purpose
Miguel Obregon [SLC] [DevOps Catalyst]23.95K Posted 28th January 2025 2 Comments
Hi Baranisudha,
I believe for your use case the best approach is to use the alarm table component. This component allows you to display alarms based on saved filters.
Update:
For example you could aggregate by severity:
Hope it helps.
Baranisudha Murugesan [DevOps Member] commented 29th January 2025
Hi Miguel, Thanks for this suggestion.
Based on the need, first I want to display the counts of my filtered alarms and if I click for more details, I should display those values.
Miguel Obregon [SLC] [DevOps Catalyst] commented 31st January 2025
Hi Baranisudha,
You could perform some aggregation in the alarm table component. I updated my answer with an example.
Hope it helps.
