Fastest way to build custom operational GUIs in DataMiner?
658 views8th July 2026
Chie Sugane50 2nd July 2026 0 Comments
Is it possible to import a custom HTML/CSS page into a DataMiner Low-Code App and simply bind DataMiner parameters to placeholders in that page?
My goal is to design the GUI in HTML and avoid recreating the entire layout manually with Low-Code components.
Is there a recommended way to achieve this?
Bert Vandenberghe [SLC] [DevOps Enabler] Answered question 8th July 2026
Bert Vandenberghe [SLC] [DevOps Enabler]10.12K Posted 8th July 2026 1 Comment
Hi Chie,
We are actually working on this as we speak. This will become available shortly. The idea is that you can easily create a UI with AI and link that to the data in DataMiner. We'll share more details about this in the coming weeks/months.
Keep an eye on the updates & insights section!
Bert
Chie Sugane Posted new comment 9th July 2026
Chie Sugane commented 9th July 2026
Hi Bert,
That sounds very promising and is exactly the direction I was hoping for.
We are currently exploring how to build more customized operational GUIs in DataMiner, and the ability to create a UI more freely and link it to DataMiner data would be very useful for us.
If there is any early information, preview, or documentation that can already be shared, it would be very helpful.
I will also keep an eye on the Updates & Insights section and look forward to hearing more details.
Best regards,
Chie
