Failover without virtual IP
Solved2.57K views11th July 2023Failover
Bernard Pichot [SLC] [DevOps Advocate]1.44K 23rd September 2021 0 Comments
Hi There,
It's now possible to setup failover with a hostname instead of virtual IP. Does this mean that the two Dataminer agents in failover configuration can be in different IP sub networks ?
Gellynck Jens [SLC]2.72K Posted 23rd September 2021 0 Comments
Yes, because there is no more virtual IP to acquire, the two agents can be in different subnets. The feature was designed for two agents running in different AWS availability zones (which can only span one subnet). So running a DMA in each of the 2 subnets (or availability zones in the image below), should be allowed:
