Extract data from a specific devices on Dataminer
Solved3.01K views19th July 2023
Javier Gordon30 22nd March 2021 0 Comments
Good afternoon team,
They could tell us if there is a way to extract data / tables from specific devices that are kept in the local dataminer database, either by means of a script or something similar.
Our dataminer version is 10.0.0.0-9517-CU6.
Regards
Miguel Obregon [SLC] [DevOps Catalyst]23.81K Posted 22nd March 2021 1 Comment
Hi Javier,
Another options (from DataMiner 10.2.0/10.1.1 onwards) it is possible to offload data to a file in the local system cache folder instead of to an offload database:
You can find more information in the DataMiner Help:
  • Offload database (File)
  • Configuring Data Offloads
The CSV files are stored in C:\Skyline DataMiner\System Cache\Offload
Miguel Obregon [SLC] [DevOps Catalyst] Posted new comment 22nd March 2021
Miguel Obregon [SLC] [DevOps Catalyst] commented 22nd March 2021
I forgot to mention that you could also use the web service API:
More information in Dojo:
https://help.dataminer.services/WebServices/#t=SLC_UM_DataMinerWebServicesWS_part_2WS_part_2.htm
