Extract data from a specific devices on Dataminer
Solved3.01K views19th July 2023
Javier Gordon30 22nd March 2021 0 Comments
Good afternoon team,
They could tell us if there is a way to extract data / tables from specific devices that are kept in the local dataminer database, either by means of a script or something similar.
Our dataminer version is 10.0.0.0-9517-CU6.
Regards
Edson Alfaro [SLC] [DevOps Advocate]1.76K Posted 22nd March 2021 0 Comments
Hi Javier,
I totally recommend to start using the New Dashboards app to look for specific information  from Dataminer, a very useful tool is the queries, so you can enroll to the course and start playing around with it.
Queries
Thanks.
Edson Alfaro [SLC] [DevOps Advocate] Answered question 22nd March 2021
