Export the routers inputs outputs names in Dataminer from VSM System
Solved1.68K views6th July 2023
6
Rahat Mehmood [DevOps Advocate]86 6th April 2023 0 Comments
Dataminer is showing only ports numbers , can we export the names of inputs and outputs from VSM System
Kawssar Marzouk [DevOps Advocate]597 Posted 7th April 2023 1 Comment
We had the same issue in our project and it was solved by editing the registry settings in the VSM itself for the DataMiner connection.
This setting is related to the Label Transfer.
Afterward, we managed to get the Labels in the DataMiner driver the same as the VSM and even when we rename the Labels in VSM; DataMiner detects the change immediately.
Rahat Mehmood [DevOps Advocate] commented 24th April 2023
Good Morning , thanks for response and providing the solution. i will contact DM support for the said changes in registry , may be after the requested upgrade to DMX version as we are still using 8.5 platform.
