Export the routers inputs outputs names in Dataminer from VSM System
Solved1.92K views6th July 2023
6
Rahat Mehmood [DevOps Advocate]86 6th April 2023 0 Comments
Dataminer is showing only ports numbers , can we export the names of inputs and outputs from VSM System
Kawssar Marzouk [DevOps Advocate]597 Posted 7th April 2023 1 Comment
We had the same issue in our project and it was solved by editing the registry settings in the VSM itself for the DataMiner connection.
This setting is related to the Label Transfer.
Afterward, we managed to get the Labels in the DataMiner driver the same as the VSM and even when we rename the Labels in VSM; DataMiner detects the change immediately.
Rahat Mehmood [DevOps Advocate] commented 24th April 2023
Good Morning , thanks for response and providing the solution. i will contact DM support for the said changes in registry , may be after the requested upgrade to DMX version as we are still using 8.5 platform.
6
Jochen Dewachter [SLC] [DevOps Member]2.17K Posted 7th April 2023 1 Comment
Our “LSB VSM” driver already supports both port numbers and input/output label names. I used it already in some projects.
In the past, I received similar question from another user and in the end they did a change inside the VSM software and then the labels appeared in DataMiner. I personally never used the VSM software directly, but I seem to remember they had to ‘add inputs/outputs to virtual matrices’ inside VSM. I’ll check if I can bring you in contact with that user and let him reply on this post if possible (unless someone else already knows the answer before that ofcourse 🙂 )
Rahat Mehmood [DevOps Advocate] Posted new comment 24th April 2023
thanks jochen for this information.
