Export element could not find DVE child element
Solved2.22K views18th July 2023element export error SRM
Timothy Van Poucke [SLC] [DevOps Advocate]1.38K 10th November 2021 0 Comments
When trying to export an element we get the error “Could not find DVE child element ID =  552770880939546” but it’s not a DVE driver. It does have resources but they are all disabled.
How could we force the export?
Davy Degrande [SLC] [DevOps Advocate]1.82K Posted 10th November 2021 2 Comments
Currently there is a bug that prevents this. Enabling the resources and moving the parent to another view can do the trick. The reason the crawling fails is because it’s encountering child element ID’s that are disabled in the view of the parent.
João Santos [SLC] commented 10th November 2021
Thank you for the feedback, we also found another similar issue in a different cluster. Instead of the error that Timothy reported we get “Export failed! Partial export for element DMAID/ElID failed”. The DMAID/ElID are the ones of the Parent DVE. This issue that I’ve mentioned, with your workaround, it works. Although, the issue presented by Timothy is not fixed with your suggestion.
Shouldn’t the “Delete All” work as well? Because, it doesn’t
