Exception while starting SLAlerter: Could not load file or assembly
Solved1.92K views16th March 2023SLAlerter
Ryan Reuss [SLC] [DevOps Member]562 17th December 2021 0 Comments
Hello Skyline Team,
Does anyone recognize the exception below? I'd appreciate some guidance troubleshooting this issue.
Task https://collaboration.dataminer.services/task/173918
Ryan Reuss [SLC] [DevOps Member] Selected answer as best 16th March 2023
Gellynck Jens [SLC]2.72K Posted 18th December 2021 1 Comment
Hi Ryan,
I don't have the exception but I did notice that there is a version mismatch between ICSharpCode.SharpZipLib.dll in C:\Skyline DataMiner\Files\SLAlerter and the one in C:\Skyline DataMiner\Files.
Left is in the alerter folder, right in the files folder (so the one SLNet has loaded), version 10.2.2):
The version was recently upgraded to 1.3.2.10 in release note 30645.
I believe this exception may also happen when your SLAlerter version does match the right DataMiner version. Please also try updating it (You can do so through this URL: https://<ip>/Tools/Installs/SLAlerterSetup.msi
If the problem would persist you could also try to copy the ICSharpCode.SharpZipLib.dll from the server to the installation folder of SLAlerter.
Michael Wells [SLC] [DevOps Member] commented 22nd December 2021
To confirm, the latest Alerter package downloaded from the DMA was equipped with the wrong version. This will need to be fixed in the next release distribution, but Unit-X is aware.
