Errors when deploying Ping Monitoring package from Catalog
Solved1.95K views3rd September 2024lowcodeapps pingmonitoring
Jon Corral [SLC] [DevOps Member]464 29th August 2024 0 Comments
SOLUTION - After internal investigation
For whom it my concern, the issue is related to a bug in Dataminer that is present since DataMiner 10.4.6 (RN 38987), where there was a change so that a protocol would be set as production if no folder existed yet in the Protocols folder for that protocol.
However, during installation of a package, what happens is that first the protocol XML file gets installed and then later the templates are installed. When the protocol XML file gets installed, it’s immediately put to production (and at the point the templates still need to be installed) so the templates did not get copied to the production version.
The install package also has a way of indicating that a version needs to be set as production and to copy the templates but that would not do anything anymore as DataMiner would see that the version that is requested to be put as production is already the production version.
With RN 40291, available since DataMiner 10.4.10, the implementation has changed a bit to overcome this problem. With this change, it will now only automatically set it to production in case a dmprotocol is installed  (if no version was uploaded yet) and only after the full dmprotocol package has been installed.
A workaround to have the package installation work on version 10.4.6-10.4.9 is to create a directory for the protocol in the install script (as this would bypass the logic to set it to production automatically). See workaround section in https://collaboration.dataminer.services/task/241354.
DESCRIPTION
Deployment of Ping Monitoring package has failed every time it has been tried in recent weeks.
This was working before, but now I have tried using different versions and different DMAs and I get errors every time I try to deploy from Catalog.
The latest attempt was done in a DaaS system.
HOW TO REPRODUCE
1. Deploy Ping Monitoring | Catalog (dataminer.services) in a cloud-connected DMA.
2. Check for errors in the Cloud Admin page
INVESTIGATION
I have tried deploying different version of Ping Monitoring package and I get this error: every time.
"errorMessage": "Unexpected exception occurred",
"exceptionMessage": "StatusCode: UnknownError, DebugMessage: A unknown exception occurred in CoreGateway: Installation of the package Ping Monitoring version 1.0.1-CU8 failed because something went wrong while running the install script: Error triggering entry point Skyline.DataMiner.Net.Automation.AutomationEntryPoint: EXIT: \"Exception encountered during installation: (Code: 0x80131500) Skyline.DataMiner.Net.Exceptions.DataMinerException: Run Subscript 'CreateDefaultPing' Failed: 0x80004005\r\n   at Skyline.DataMiner.Automation.Engine.InternalLaunchSubScript(String scriptName, List`1 finalOptions, Int32 inheritSubScript, Int32 extendedErrorInfo, Dictionary`2& subScriptOutput, List`1& errorMessages)\r\n   at Skyline.DataMiner.Automation.SubScriptOptions.StartScript()\r\n   at Script.Install(Engine engine, AppInstallContext context)\", DmaId: 1003814",
"stackTrace": "   at ArtifactDeployer.Services.CoreGateWayResponseHandler.Implementations.CoreGateWayResponseHandler.Handle[TReq,TResp](ICoreGatewayRequestExecutor coreGatewayRequestExecutor, TReq request, MessageParser`1 responseParser, String topicId)\r\n   at ArtifactDeployer.Deployer.Implementations.AppPackageDeployer.Deploy(String deploymentId, EventingInfo eventingInfo, ArtifactInfo info, String artifactLocation, DeployContext context)\r\n   at ArtifactDeployer.Handler.Implementations.DeploymentHandlerEventingDecorator.<>c__DisplayClass7_0.<<DeployArtifactAsync>b__0>d.MoveNext()\r\n--- End of stack trace from previous location ---\r\n   at ArtifactDeployer.Handler.Implementations.DeploymentHandlerEventingDecorator.CaptureExceptionAsync(ContextType contextType, Func`1 action)"
QUESTION
Is this something you have seen before? Seems to be specific for this LCA, and it has been reproduced over several systems, both DAAS and not DAAS. Last try, was on a freshly installed DAAS running the latest version of Dataminer (10.4.8.0-14612).
MORE INFORMATION
We tried installing the dmapp on previous versions of Dataminer, and 10.4.1 and it seems it works, while it fails in newer versions. The issue seems to be the following
024/08/29 16:01:06.076|SLAutomation.exe 10.4.2432.678|20916|47744|CSharp|DBG|5|(Script CreateDefaultPing/1) Extended Error Info:
(Code: 0x80131500) Skyline.DataMiner.Automation.ScriptAbortException: Sequence contains no matching element
at Skyline.DataMiner.Automation.Engine.ExitFail(String reason)
at CreateDefaultPing_1.Script.Run(IEngine engine)
2024/08/29 16:01:06.078|SLAutomation.exe 10.4.2432.678|20916|47744|CScriptLoader::ExitNow|DBG|-1|[Baptiste Pattyn] (Script CreateDefaultPing) EXIT: “Sequence contains no matching element”
2024/08/29 16:01:06.079|SLAutomation.exe 10.4.2432.678|20916|47744|CScriptLoader::FinalActions|DBG|3|[Baptiste Pattyn] (Script CreateDefaultPing) Script execution FAILED
2024/08/29 16:01:06.092|SLAutomation.exe 10.4.2432.678|20916|47744|CAutomation::Execute|INF|0|[Baptiste Pattyn] Finished executing script: ‘CreateDefaultPing’ (ID: 48) – FAILED – Execution took 00.520s.
2024/08/29 16:01:06.096|SLAutomation.exe 10.4.2432.678|20916|64052|CSharp|DBG|5|(Script Ping Monitoring_1.0.1-CU8_InstallScript_2643ce95de1648e18f217533bd205057/1) Extended Error Info:
(Code: 0x80131500) Skyline.DataMiner.Automation.ScriptAbortException: Exception encountered during installation: (Code: 0x80131500) Skyline.DataMiner.Net.Exceptions.DataMinerException: Run Subscript ‘CreateDefaultPing’ Failed: 0x80004005
This CreateDefaultPing creates a default Ping Element when the app is deployed from the catalog.
Any idea why this might be failing in newer versions?
Jon Corral [SLC] [DevOps Member] Changed status to publish 3rd September 2024
Alexander Verkest [SLC] [DevOps Advocate]1.42K Posted 29th August 2024 1 Comment
This is not an error related to dataminer.services or the catalog, the package install script itself seems to be broken.
I have tried installing the package directly to a DMS and it failed, tested on v10.4.10.
Kind regards,
Jon Corral [SLC] [DevOps Member] Posted new comment 29th August 2024
Jon Corral [SLC] [DevOps Member] commented 29th August 2024
Hello Alexander, we tried installing the dmapp on previous versions of Dataminer, and 10.4.1 and it seems it works, while it fails in newer versions. The issue seems to be the following
