Error when trying to launch DataMiner using https
Solved939 views18th July 2023
Carlos Trejo20 21st October 2021 0 Comments
We are having a scenario where we can RDP into the DataMiner servers and launch DM using http, but when we try to launch the application using https  we get this error:
Are we missing something?
Thanks!
Gellynck Jens [SLC]2.71K Posted 22nd October 2021 0 Comments
At first, it seems the issue is not related to the certificate so I would recommend clearing the XBAP cache and re-trying.
