Error when trying to create DataMiner Element programmatically
Solved1.58K views14th July 2023
Alexander Hewitson 25th April 2022 0 Comments
Hello,
I'm getting the following error when trying to programmatically create element in DataMiner.
2022/04/25 14:51:25.291|SLManagedScripting.exe|ManagedInterop|ERR|1|28|NMLOG|[GetNumberOfElements]|Exception => System.ArgumentException DataMiner agent ID in "4294967295/4294967295" is not an integer value
Parameter name: id ( [GetNumberOfElements] )
at Skyline.DataMiner.Library.Common.DmsElementId..ctor(String id)
at Skyline.DataMiner.Library.Common.ReplicationSettings.Load(ElementInfoEventMessage elementInfo)
at Skyline.DataMiner.Library.Common.DmsElement.ParseElementInfo(ElementInfoEventMessage elementInfo)
at Skyline.DataMiner.Library.Common.DmsElement.Parse(ElementInfoEventMessage elementInfo)
at Skyline.DataMiner.Library.Common.DmsElement..ctor(IDms dms, ElementInfoEventMessage elementInfo)
at Skyline.DataMiner.Library.Common.Dma.GetElements()
at OneWeb.SkylineClassCommon.GetNumberOfElements(ISLProtocolWrapper protocol, Int32 agentId)
This previously worked without issue so can't understand why I'm having trouble with this now.
I'm currently running DataMiner Version (10.2.4.0-11608)
Gellynck Jens [SLC]2.71K Posted 25th April 2022 2 Comments
Hi Alexander,
This looks to be a combination of 2 issues:
  1. DataMiner is returning an element with an invalid DataMiner / Element ID.
  2. The class library is failing to parse this invalid ID when retrieving the Number of Elements, while it should probably handle this invalid ID better and return the number of valid elements.
You can likely fix this issue by deleting the element with the invalid ID. To find this element you can check the alarm console for errors/notices or looking for related errors in the DataMiner logging (most likely SLDataMiner.txt, SLErrors.txt, SLNet.txt). You may also be able to find this element by opening the root view card, selecting "elements" (below this view), then sorting on the "ID" column (look for an element that has ID 0).
Alexander Hewitson Posted new comment 26th April 2022
Alexander Hewitson commented 26th April 2022
I wasn’t able to find any elements with an ID of 0.
We’re using the following methods to call this:
public static string GetElementFullId(ISLProtocolWrapper protocol, int agentId, string elementName)
string elementId = null;
protocol.Log(string.Format(“[GetElementFullId] From Agent agentId={0} elementName = {1}”, agentId, elementName), Severity.DEBUG);
try
IDms dms = protocol.getDms();
IDma agent = dms.GetAgent(agentId);
IDmsElement dmsElement = agent.GetElement(elementName);
elementId = GetElementFullId(dmsElement);
protocol.Log(string.Format(“[GetElementFullId] From Agent elementId = {0} for {1}”, elementId, elementName), Severity.DEBUG);
catch (Exception e)
protocol.Log(e, “[GetElementFullId] From Agent id=” + agentId, Severity.DEBUG);
return elementId;
public static string GetElementFullId(IDmsElement dmsElement)
string fullId = null;
if (dmsElement != null)
fullId = dmsElement.DmsElementId.AgentId + “/” + dmsElement.DmsElementId.ElementId;
return fullId;
It’s also worth noting that we’re in a 4 agent cluster, with a CNMA having a failover pair.
