Error on publishing script – Could not establish trust relationship for the SSL/TLS secure channel
Solved1.32K views26th June 2025Automation DIS Automation script DIS publish Visual Studio
Baranisudha Murugesan [DevOps Member]1.16K 7th March 2025 2 Comments
When i tried to connect and publish the code from Visual studio 2022 and DIS version 3.1.6 in windows 11, I get this error -
I tried test connection with dev dataminer, connection is successful but when i try to publish, im getting the SSL error.
I have updated the visual studio and restarted the machine but still same.
Apurva Tandon [DevOps Advocate] commented 7th March 2025
I am facing the same issue
Windows 11
Visual Studio Version: Version 17.13.2
DIS version : 3.1.6
I see when go to DIS connect on test connection it says succeeded but when I connect to agent it throws the error same as Barani added
Even I restarted Dataminer Cloud and Clore Gateway services too then also issue remains
Seppe Dejonckheere [SLC] [DevOps Enabler] commented 14th March 2025
A new update for DIS is available. This should resolve the issue.
Seppe Dejonckheere [SLC] [DevOps Enabler]2.74K Posted 7th March 2025 1 Comment
I believe the error you are seeing is the result of the TLS certificate of the DMA you are connecting to is not trusted on your machine.
Can you verify which certificate is configured on the DMA? You can check this by inspecting the https binding in IIS:
Kind regards,
Apurva Tandon [DevOps Advocate] Posted new comment 7th March 2025
Hi yes, I tried but not working yet the certificate is configured properly>
Please see image in answer below
