Error on publishing script – Could not establish trust relationship for the SSL/TLS secure channel
Solved2.13K views26th June 2025Automation DIS Automation script DIS publish Visual Studio
Baranisudha Murugesan [DevOps Member]1.19K 7th March 2025 2 Comments
When i tried to connect and publish the code from Visual studio 2022 and DIS version 3.1.6 in windows 11, I get this error –
I tried test connection with dev dataminer, connection is successful but when i try to publish, im getting the SSL error.
I have updated the visual studio and restarted the machine but still same.
Apurva Tandon [DevOps Member] commented 7th March 2025
I am facing the same issue
Windows 11
Visual Studio Version: Version 17.13.2
DIS version : 3.1.6
I see when go to DIS connect on test connection it says succeeded but when I connect to agent it throws the error same as Barani added
Even I restarted Dataminer Cloud and Clore Gateway services too then also issue remains
Seppe Dejonckheere [SLC] [DevOps Enabler] commented 14th March 2025
A new update for DIS is available. This should resolve the issue.
Apurva Tandon [DevOps Member]1.73K Posted 7th March 2025 3 Comments
The certificate is configured properly
Seppe Dejonckheere [SLC] [DevOps Enabler] commented 7th March 2025
What url or ip are you using to connect to the DMA? Can you verify if that url/ip is listed in the Subject or the Subject Alternative Names under the details tab of the certificate info?
Yes it is, my point is when I do test connection it succeeds means everything is good, on DIS connect it throws this error why?
The reason is that the test connection checks the conventional connection towards the DMA (.NET remoting or gRPC). However, in the latest version, DIS also requires an HTTPS connection to the DMA, which is not checked when testing the connection.
Seppe Dejonckheere [SLC] [DevOps Enabler]3.05K Posted 7th March 2025 1 Comment
I believe the error you are seeing is the result of the TLS certificate of the DMA you are connecting to is not trusted on your machine.
Can you verify which certificate is configured on the DMA? You can check this by inspecting the https binding in IIS:
Kind regards,
Apurva Tandon [DevOps Member] Posted new comment 7th March 2025
Hi yes, I tried but not working yet the certificate is configured properly>
Please see image in answer below
