Error in automation due to Label
Solved2.51K views18th October 2023automation engine Skyline.DataMiner.Automation SLAutomation
Amer Hodzic [DevOps Member]784 19th June 2023 4 Comments
Hi Dojo Community,
I have a quick question as I am trying to use the MessageBox in a script I am working on and have ran into this issue with it:
SLAutomation.exe 10.3.2243.4394|18748|15056|CSharp|DBG|5|(Script Event_Streaming/1) Extended Error Info:
(Code: 0x80131500) Skyline.DataMiner.Automation.ScriptAbortException: Whoopsy System.TypeLoadException: Der Typ "Text" in der Assembly "SLManagedAutomation, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null" konnte nicht geladen werden.
bei Skyline.DataMiner.Utils.InteractiveAutomationScript.Label.StyleToUiString(TextStyle textStyle)
Now I had this issue before when trying to create a label myself so I avoided using the labels in Dialogs.
Here is also the code for the MessageBox:
controller.Engine.Log("Entering the else condition");
MessageDialog exceptionDialog = new MessageDialog(controller.Engine, "Ip Address is invalid please type in a new one");
exceptionDialog.Show(true);
Thank you so much in advance
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 18th October 2023
Marieke Goethals [SLC] [DevOps Catalyst] commented 30th June 2023
Hi Amer,
I see that this question has been inactive for some time now. Have you found a solution for this yet? If not, feel free to contact techsupport@skyline.be for assistance.
Amer Hodzic [DevOps Member] commented 30th June 2023
no still is the same problem
Thomas Cauwelier [SLC] [DevOps Advocate] commented 3rd July 2023
Hi Amer,
I would need to see the visual studio solution to find what else could be causing the problem.
Would it be possible to put the solution on github and share the link?
Or if it contains secrets, put a stripped down version on github.
If this is not possible, I suggest contacting techsupport@skyline.be so we can help you through that channel.
Marieke Goethals [SLC] [DevOps Catalyst] commented 18th October 2023
Hi Amer,
As this problem is too complex to solve it here on the forum, I will now close this question. As Thomas suggested, if you cannot share the solution with him on GitHub, feel free to contact techsupport@skyline.be so they can assist you.
Thomas Cauwelier [SLC] [DevOps Advocate]1.86K Posted 19th June 2023 3 Comments
Hi Amer,
Can you check if the correct toolkit version gets uploaded to DataMiner?
Also, make sure that there is no toolkit dll file in the "C:\Skyline DataMiner\Files" folder
When in the Files folder, it will override all other references to it.
Amer Hodzic [DevOps Member] commented 19th June 2023
Checked both and they are ok but still the same issue
Thomas Cauwelier [SLC] [DevOps Advocate] commented 20th June 2023
Try putting the same 4.0.0 version on all automation scripts and restart DataMiner.
Amer Hodzic [DevOps Member] commented 20th June 2023
tried that as well same issue, since I started working with the dialogs Labels never worked for me
