Error connecting to DMA using DIS.
Solved1.91K views17th March 2025
Vishal Grover69 6th March 2025 2 Comments
I am having issues connecting to DMA using DIS. When i run test using settings its successful however when i actually connect Via DIS its failing with following error.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 17th March 2025
Vishal Grover commented 6th March 2025
2025/03/05 21:38:45.815|Trying to connect to DMA with hostname '10.144.66.197' and username 'CORPGroverV0506'!
2025/03/05 21:38:45.815|Starting new SLDisDmaComm service process
2025/03/05 21:38:45.932|> Process started: PID 48640
2025/03/05 21:38:46.008|> Guid: 57893106-5299-4911-90bd-3ddd82d4e369
2025/03/05 21:38:46.008|> Host: 10.144.66.197
2025/03/05 21:38:46.014|> Starting service
2025/03/05 21:38:46.090|> net.pipe://127.0.0.1/57893106-5299-4911-90bd-3ddd82d4e369/SLDisDmaComm
2025/03/05 21:38:46.104|> Service is started!
2025/03/05 21:38:46.104|SLDisDmaComm service PID: 48640
2025/03/05 21:38:46.105|Connecting to SLDisDmaComm service process
2025/03/05 21:38:46.107|Connected to SLDisDmaComm service process!
2025/03/05 21:38:46.127|> Executing RegisterCallback
2025/03/05 21:38:46.139|> Executing Connect (hostname: 10.144.66.197, username: CORPGroverV0506)
2025/03/05 21:38:46.147|> Parent process: devenv (33984)
2025/03/05 21:38:56.967|> Resolving assembly: SLProtoBufLibrary.XmlSerializers, Version=1.0.0.0, Culture=neutral, PublicKeyToken=9789b1eac4cb1b12
2025/03/05 21:38:56.968|> Trying to load assembly from package: SLProtoBufLibrary.XmlSerializers
2025/03/05 21:38:56.968|> Could not find file in DIS package.
2025/03/05 21:38:56.968|> Trying to load assembly via service: SLProtoBufLibrary.XmlSerializers, Version=1.0.0.0, Culture=neutral, PublicKeyToken=9789b1eac4cb1b12
2025/03/05 21:38:56.968|> Getting path via service…
2025/03/05 21:38:56.986|> Path:
2025/03/05 21:38:56.986|> Could not load assembly 'SLProtoBufLibrary.XmlSerializers'.
2025/03/05 21:39:01.534|> Failed to retrieve connection for WebApi with exception: System.Net.Http.HttpRequestException: An error occurred while sending the request. —> System.Net.WebException: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel. —> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure.
2025/03/05 21:39:01.534|> at System.Net.TlsStream.EndWrite(IAsyncResult asyncResult)
2025/03/05 21:39:01.535|> at System.Net.ConnectStream.WriteHeadersCallback(IAsyncResult ar)
2025/03/05 21:39:01.535|> — End of inner exception stack trace —
2025/03/05 21:39:01.536|> at System.Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
2025/03/05 21:39:01.536|> at System.Net.Http.HttpClientHandler.GetRequestStreamCallback(IAsyncResult ar)
2025/03/05 21:39:01.536|> — End of inner exception stack trace —
2025/03/05 21:39:01.536|> at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
2025/03/05 21:39:01.536|> at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
2025/03/05 21:39:01.536|> at Nito.AsyncEx.Synchronous.TaskExtensions.WaitAndUnwrapException[TResult](Task`1 task)
2025/03/05 21:39:01.536|> at SLDisDMAComm.SLDisDmaCommService.ConnectToWebApi() in D:aDISDISProtocolEditorSLDisDMACommSLDisDmaCommService.cs:line 1203
2025/03/05 21:39:01.536|> Exception during Connect: System.ServiceModel.FaultException: System.Net.Http.HttpRequestException: An error occurred while sending the request. —> System.Net.WebException: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel. —> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure.
2025/03/05 21:39:01.536|> at System.Net.TlsStream.EndWrite(IAsyncResult asyncResult)
2025/03/05 21:39:01.536|> at System.Net.ConnectStream.WriteHeadersCallback(IAsyncResult ar)
2025/03/05 21:39:01.537|> at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
2025/03/05 21:39:01.537|> at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
2025/03/05 21:39:01.537|> at Nito.AsyncEx.Synchronous.TaskExtensions.WaitAndUnwrapException[TResult](Task`1 task)
2025/03/05 21:39:01.537|> at SLDisDMAComm.SLDisDmaCommService.ConnectToWebApi() in D:aDISDISProtocolEditorSLDisDMACommSLDisDmaCommService.cs:line 1203
2025/03/05 21:39:01.537|> at SLDisDMAComm.SLDisDmaCommService.ConnectToWebApi() in D:aDISDISProtocolEditorSLDisDMACommSLDisDmaCommService.cs:line 1224
2025/03/05 21:39:01.537|> at SLDisDMAComm.SLDisDmaCommService.Connect(String hostname, String username, String password, String accessToken) in D:aDISDISProtocolEditorSLDisDMACommSLDisDmaCommService.cs:line 219
2025/03/05 21:39:01.538|> Finished executing Connect (hostname: 10.144.66.197, username: CORPGroverV0506)
2025/03/05 21:39:01.538|> Connection Type: GRPCConnection
2025/03/05 21:39:01.542|Could not connect to DMA! :
System.ServiceModel.FaultException: System.ServiceModel.FaultException: System.Net.Http.HttpRequestException: An error occurred while sending the request. —> System.Net.WebException: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel. —> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure.
Server stack trace:
at System.ServiceModel.Channels.ServiceChannel.HandleReply(ProxyOperationRuntime operation, ProxyRpc& rpc)
at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at SLDisDMACommShared.ISLDisDmaCommService.Connect(String hostname, String username, String password, String accessToken)
at SLDisDMACommClient.DmaClient.Connect(Guid id, String hostname, String username, String password, String accessToken) in D:aDISDISProtocolEditorSLDisDMACommClientDmaClient.cs:line 199
2025/03/05 21:39:01.542|Cleaning up SLDisDmaComm resources
2025/03/05 21:39:01.557|>
I have another DMA that i am trying to connect to and i am seeing – System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it [::1]:80
Peter den Bak [DevOps Advocate]97 Posted 7th March 2025 1 Comment
Hi Michiel
I don't have an answer, but just want to report the exact same issue with DIS 3.1.6
Both production and Lab have the same issue
Michiel Oda [SLC] [DevOps Advocate] Posted new comment 7th March 2025
Michiel Oda [SLC] [DevOps Advocate] commented 7th March 2025
Hi Peter
This issue is only present since the lastest DIS version. As mentioned in my post, DIS is now also connecting to the DataMiner WebServices. As mentioned in the following question: https://community.dataminer.services/question/error-on-publishing-script-could-not-establish-trust-relationship-for-the-ssl-tls-secure-channel/
could you check if the certificate is correct and valid and if nothing is blocked on the firewall regarding the DataMiner WebServices?
