Equivalence of Methods GetElementNameByPollingIp of https
Solved742 views27th June 2025
Dossah Steeve34 25th January 2024 3 Comments
Hello,
The method GetElementNameByPollingIp is used this to request a list of all the elements that poll a specific IP address.  I’m looking equivalent method for http/s.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 27th June 2025
Dossah Steeve commented 30th January 2024
It’s exactly What I’m looking for. If some one know the equivalence of the method GetElementNameByPolling for http/s. I wil realy appreciate to know
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th March 2025
Hi Dossah,
Marieke Goethals [SLC] [DevOps Catalyst] commented 27th June 2025
Miguel Obregon [SLC] [DevOps Catalyst]22.20K Posted 25th January 2024 0 Comments
Hi Dossah,
If I understand correctly, you would like to get the hostname defined in the ip address/host defined in the element settings:
If this is the case, I believe you can pass the hostname (instead of the IP address) to filter the list of elements.
