Equipment not visible in Rack View
Solved1.80K views14th July 2023Rack View
Thomaz Malmberg [DevOps Member]523 30th June 2022 0 Comments
Does anyone have an idea why some of my equipment is visible in the Rack View and some not?
João Severino [SLC] [DevOps Enabler]14.78K Posted 30th June 2022 2 Comments
Hi Thomaz
Can you try the Refresh & Rebuild option?
It can be found under the IDP Application Visual Overview on the Admin > Facilities > Rack Assignment
Thomaz Malmberg commented 1st July 2022
Hi João,
Thanks for the tips, but that didn´t helped. Nothing happened when I used “Refresh & Rebuild”
João Severino [SLC] [DevOps Enabler] commented 1st July 2022
Hi Thomaz,
Sorry to hear it did not fix the issue.
The only thing I could suggest to you without a more extensive investigation is to check if the element in question is listed on the Rack Assignment table (the one that can be seen in my original reply) and if in there it also shows the correct information regarding its location.
Also, if the element is listed there, does the Show in Rack button navigates you to the correct view?
Otherwise, I would advise you to reach out to your Skyline contact so an investigation can be done.
