Enable Advanced Editing tool in Visio
Solved1.86K views26th April 2022Advanced Editing Visio
Randy Ulvenes [SLC] [DevOps Member]1.31K 25th April 2022 0 Comments
How do I add or enable the Advanced Editing Tool in Visio if it is closed?
Randy Ulvenes [SLC] [DevOps Member] Selected answer as best 26th April 2022
Miguel Obregon [SLC] [DevOps Catalyst]23.86K Posted 26th April 2022 2 Comments
Hi Randy,
When editing your overview in Visio, you should see the extra tab 'Add-ins' in the menu bar:
When clicking 'Advanced editing' you should visualize the toolbar.
Randy Ulvenes [SLC] [DevOps Member] Posted new comment 26th April 2022
Sebastiaan Dumoulein [SLC] [DevOps Enabler] commented 26th April 2022
Do note that this add-in is pushed from Cube in Visio when doing an ‘Edit in Visio’/’New blank’. This means you will not have this when regularly opening Visio or after closing Cube.
Randy Ulvenes [SLC] [DevOps Member] commented 26th April 2022
Thanks for the answers!
