Embed an application running on localhost in Low-Code application
Solved2.75K views23rd January 2025#lowcodeapplication low-code LowCode lowcodeapps
Ladan Razeghi [DevOps Catalyst]1.09K 25th July 2024 2 Comments
Hi All
Is there anyway that we embed an application running on localhost into Low-Code Application?
We have a React UI which we like to run it locally and embed it in Low-Code app.
Marieke Goethals [SLC] [DevOps Catalyst] commented 22nd November 2024
Hi Ladan,
Marieke Goethals [SLC] [DevOps Catalyst] commented 23rd January 2025
Miguel Obregon [SLC] [DevOps Catalyst]23.67K Posted 25th July 2024 1 Comment
Hi Ladan,
I believe there is already a similar question:
Can we embed an angular or React application inside low code application?
Hope it helps.
Ladan Razeghi [DevOps Catalyst] Posted new comment 25th July 2024
Ladan Razeghi [DevOps Catalyst] commented 25th July 2024
This is different. There’s no external URL to embed in LCA. my question is if the react can be run locally on dma server. Can we use same approach?
