Element two tables and an idx (inside children)
Solved893 views1st March 2023
Stefan Schedletzky [DevOps Advocate]2.48K 28th February 2023 0 Comments
I have a drawing with Children which is displaying several services. For one element I have two tables where I have information which should be displayed as a child.
This is is the first table and how I receive the correct idx for the next table:
My question is now do I need to have a session variable to store this parameter information to use it?
Or is there any other chance to use it directly. For example something like this:
Parameter: 12345:Encoder*:14018:*[Property:CHANNEL_ENCODER]*
But I guess this will not work or?
Thanks!
Stefan Schedletzky [DevOps Advocate] Selected answer as best 1st March 2023
Michiel Vanthuyne [SLC] [DevOps Advocate]4.79K Posted 1st March 2023 2 Comments
Hi Stefan,
This should be possible using the [param] placeholder, so something like
Parameter: 12345:[param:Encoder*,14018,*[Property:CHANNEL_ENCODER]*]
Michiel Vanthuyne [SLC] [DevOps Advocate] Posted new comment 1st March 2023
Stefan Schedletzky [DevOps Advocate] commented 1st March 2023
Hi Michiel,
thanks for your answer. It was not working and I did some tests finally I just need to use , instead of :
12345:*[param:Encoder*,14018,*[Property:CHANNEL_ENCODER]*]*
Michiel Vanthuyne [SLC] [DevOps Advocate] commented 1st March 2023
Hi Stefan,
I’m glad you found a solution! Inside the placeholder you indeed need to use the comma instead of the colon as separator. I’ve updated the answer so other people can find the correct syntax immediately.
