Element startup order
Solved2.32K views19th July 2023
Jeff Douglass870 23rd December 2020 0 Comments
During a DMA startup, either a stand alone DMA or the offline DMA in a Failover being brought online, is there an order to how all the elements are started up. For example does DM start elements based on their IDs with the lowest IDs being started first?
Thanks
Wouter Demuynck [SLC] [DevOps Advocate]7.04K Posted 24th December 2020 0 Comments
There's no guaranteed order in which elements get started.
