element not initialized
Solved2.34K views21st April 2021DataMiner Cube elements initialized
roxana irinei 14th April 2021 1 Comment
Hello!
I am trying to follow along this training: https://community.dataminer.services/video/dataminer-inspire-creating-a-driver-from-scratch/ And i have my AWS server setup, like in the training. I added it to DataMiner, but the state is “not initialized” and i cannot perform any tasks on it (as they are described in the training). Can someone explain to me how this initialization works and what i need to do to make it happen?
Many thanks!
roxana irinei Selected answer as best 21st April 2021
Ive Herreman [SLC] [DevOps Enabler] commented 14th April 2021
Hi Roxanna,
Would you be able to share a screenshot of what you get?
Ive Herreman [SLC] [DevOps Enabler]14.40K Posted 14th April 2021 7 Comments
Hi Roxanna,
Parameters in an element will show “not initialized” until a value has been set in those parameters.
Parameters can be set from different sources, based on their purpose.
e.g.
-a parameter for a username or password is typically set by the user.
-a parameter representing a KPI is typically set by a retrieved value from the remote data source (through a QAction, action, SNMP reply, etc).
Which parameters are currently “not initialized”?
Have you already added the HTTP sessions, triggers, and actions to your protocol?
roxana irinei commented 14th April 2021
Hey, Ive! Thanks for reaching out!
So, what i am trying to do is poll a CloudWatch API from AWS and retrieve information on some metrics of an EC2 instance. i configured the QActions and params as in the video-training, but all i get is “not initialized” on DataMiner Cube. I am trying to attach a picture, but i don’t see the button for it anymore. :/
EDIT: I managed to attach a picture to the question. Also, i wanna mention that i restarted the element in DMCube, as taught in the training, but i don;t get the same result. The trainer gets the field populated with the metric data in json format, i get “not initialized”.
Hi Roxanna,
Thank you for the additional information.
To start the investigation, can you please check the following things:
1. If you right-click the element and choose View -> streamviewer, you get an overview of all communication between DataMiner and the remote data source. Do you see any communication here? (you might need to restart your element to see a request pass by in case you use an after startup trigger).
2. If you right-click the element and choose View -> log, you get the element logging. Are there any errors visible here?
If i do View > Stream Viewer, i see nothing. the window is blank.
this is what i have in View > Logs
Logfile “aws_winserver_api” from agent “10.0.0.4”…
2021/04/14 12:17:56.520|SLLog|ApplyLogLevels|CRU|-1|Log Levels: Info: 5; Error: 5; Debug: 5 (init)
2021/04/14 12:17:56.529|SLDataMiner.exe – aws_winserver_api|8592|CElement::SetState|DBG|0|** Setting state finished.
2021/04/14 12:17:56.530|SLDataMiner.exe – aws_winserver_api|8592|CElement::CreateObjects|INF|-1|** Creating objects for element aws_winserver_api (23)
2021/04/14 12:17:56.530|SLDataMiner.exe – aws_winserver_api|8592|CElement::Start|INF|-1|** Creating objects for element aws_winserver_api (23)
2021/04/14 12:17:56.564|SLDataMiner.exe – aws_winserver_api|8592|CElement::GetPortInfoAsString|DBG|5|0 0 3 0 2 0 3 0 1500 ByPassProxy 80 monitoring.us-east-2.amazonaws.com 30000 0 0 0 -1 1500 0
2021/04/14 12:17:56.565|SLProtocol – 1976 – |16828|CProtocol::InitFunc|CRU|0|– Start Init
2021/04/14 12:17:56.565|SLProtocol – 1976 – |16828|CProtocol::Init|INF|1|Creating protocol Aws cloudwatch api
–> version 1.0.0.1 (1.0.0.1)
2021/04/14 12:17:56.566|SLProtocol – 1976 – |16828|CProtocol::InitFunc|CRU|0|ReadSettings
2021/04/14 12:17:56.596|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|Log elementInProtocol
2021/04/14 12:17:56.604|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|InitializeDefinitions
2021/04/14 12:17:56.604|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|InitializeParameters
2021/04/14 12:17:56.605|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitializeParameters|CRU|-1|LoadOthersAndExceptions
2021/04/14 12:17:56.605|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitializeParameters|CRU|-1|Simulation
2021/04/14 12:17:56.605|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitializeParameters|CRU|-1|Element data
2021/04/14 12:17:56.607|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::LoadElementDataSinglePIDs|CRU|-1|Querying elementdata
2021/04/14 12:17:56.640|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitializeParameters|CRU|-1|Reading item data
2021/04/14 12:17:56.641|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitializeParameters|CRU|-1|Begin processing parameters
2021/04/14 12:17:56.642|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitializeParameters|CRU|-1|Find ids
2021/04/14 12:17:56.642|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitializeParameters|CRU|-1|Removing duplicates
2021/04/14 12:17:56.642|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitializeParameters|CRU|-1|Initializing hash table
2021/04/14 12:17:56.642|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitializeParameters|CRU|-1|Loading parameters
2021/04/14 12:17:56.643|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitializeParameters|CRU|-1|done Loading parameters
2021/04/14 12:17:56.643|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|InitializeCommands
2021/04/14 12:17:56.643|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|InitializeResponses
2021/04/14 12:17:56.643|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|InitializePairs
2021/04/14 12:17:56.643|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|InitializeGroups
2021/04/14 12:17:56.644|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|InitializeTimers
2021/04/14 12:17:56.644|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|InitializeTriggers
2021/04/14 12:17:56.644|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|InitializeActions
2021/04/14 12:17:56.644|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|InitializeQActions
2021/04/14 12:17:56.645|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|Cleaning QAction Instances
2021/04/14 12:17:56.646|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|InitializeSessions
2021/04/14 12:17:56.646|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|SetupParameters 162(#) * 444(b) = 71928
2021/04/14 12:17:56.650|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::CheckDBTables|DBG|-1|BuildIndex for PID 65135 took 0 ms
2021/04/14 12:17:56.650|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::CheckDBTables|DBG|-1|BuildIndex for PID 65143 took 0 ms
2021/04/14 12:17:56.650|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::CheckDBTables|DBG|-1|BuildIndex for PID 65073 took 0 ms
2021/04/14 12:17:56.650|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::CheckDBTables|DBG|-1|BuildIndex for PID 65148 took 0 ms
2021/04/14 12:17:56.650|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::CheckDBTables|DBG|-1|BuildIndex for PID 65059 took 0 ms
2021/04/14 12:17:56.650|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::CheckDBTables|DBG|-1|BuildIndex for PID 65062 took 0 ms
2021/04/14 12:17:56.650|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::CompleteLoadSequence|DBG|-1|Load Sequence: 65132,65146,65139,65049,65054,65060,65068
2021/04/14 12:17:56.650|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|LinkReadWrite
2021/04/14 12:17:56.650|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|InitializeAlarmLevelLinks
2021/04/14 12:17:56.650|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|InitializeReplication
2021/04/14 12:17:56.650|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|InitializeVirtualFunctionBinding
2021/04/14 12:17:56.650|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|SetupCommands 0(#) * 112(b) = 0
2021/04/14 12:17:56.651|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|SetupResponses 0(#) * 224(b) = 0
2021/04/14 12:17:56.651|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|SetupPairs 0(#) * 72(b) = 0
2021/04/14 12:17:56.651|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|SetupGroups 2(#) * 116(b) = 232
2021/04/14 12:17:56.651|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|SetupTimers 3(#) * 568(b) = 1704
2021/04/14 12:17:56.651|SLProtocol – 1976 – aws_winserver_api|16828|CTimer::InitTimerThread|DBG|2| Timer thread started (0x00002DD4 – 6400) (bInitial = 1, m_uiDataDisplayTime = -1, m_uiTime = 10000)
2021/04/14 12:17:56.651|SLProtocol – 1976 – aws_winserver_api|16828|CTimer::InitTimerThread|DBG|2| Timer thread started (0x00002DE0 – 9016) (bInitial = 1, m_uiDataDisplayTime = 30000, m_uiTime = 60000)
2021/04/14 12:17:56.651|SLProtocol – 1976 – aws_winserver_api|6400|CTimer::TimerThreadFunc|DBG|2|Launched Timer thread
2021/04/14 12:17:56.651|SLProtocol – 1976 – aws_winserver_api|16828|CTimer::InitTimerThread|DBG|2| Timer thread started (0x00002DE4 – 1412) (bInitial = 1, m_uiDataDisplayTime = -1, m_uiTime = 3600000)
2021/04/14 12:17:56.651|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|SetupActions 5(#) * 68(b) = 340
2021/04/14 12:17:56.651|SLProtocol – 1976 – aws_winserver_api|9016|CTimer::TimerThreadFunc|DBG|2|Launched Timer thread
2021/04/14 12:17:56.651|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|SetupTriggers 4(#) * 84(b) = 336
2021/04/14 12:17:56.651|SLProtocol – 1976 – aws_winserver_api|1412|CTimer::TimerThreadFunc|DBG|2|Launched Timer thread
2021/04/14 12:17:56.651|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|MakeCommands
2021/04/14 12:17:56.651|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|SetupQActions 13(#) * 196(b) = 2548
2021/04/14 12:17:56.652|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|SetupSessions 0(#) * 140(b) = 0
2021/04/14 12:17:56.652|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|– Total not filled in size is 77088 b
2021/04/14 12:17:56.652|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::InitFunc|CRU|0|– Done Init
2021/04/14 12:17:56.652|SLDataMiner.exe – aws_winserver_api|8592|CElement::InitializeElement_SLElement|DBG|-1|Initializing SLElement…
2021/04/14 12:17:56.652|SLElement.exe|21804|CElement::Init()|DBG|-1|** Initializing IElement …
2021/04/14 12:17:56.652|SLElement.exe|21804|CElement::ReadSettings|DBG|-1|** Read Settings…
2021/04/14 12:17:56.653|SLElement.exe|21804|CElement::ReadSettings|DBG|-1|** Initialize Connections…
2021/04/14 12:17:56.653|SLElement.exe|21804|CElement::ReadSettings|DBG|-1|** Read Settings Complete…
2021/04/14 12:17:56.653|SLElement.exe|21804|CElement::Init|DBG|-1|** Initializing IElement Complete…
2021/04/14 12:17:56.653|SLDataMiner.exe – aws_winserver_api|8592|CElement::InitializeElement_SLElement|DBG|-1|Notifying view settings…
2021/04/14 12:17:56.653|SLDataMiner.exe – aws_winserver_api|8592|CElement::Start|DBG|-1|Starting protocol…
2021/04/14 12:17:56.653|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::Start|CRU|-1|Starting SLElement
2021/04/14 12:17:56.653|SLElement.exe|21804|CElement::StartFunc|CRU|-1|** Starting
2021/04/14 12:17:56.653|SLElement.exe|21804|CElement::Start2|CRU|-1|** Read DB
2021/04/14 12:17:56.653|SLElement.exe|21804|CElement::ReadDB|CRU|-1|** Read DB [latch]
2021/04/14 12:17:56.672|SLElement.exe|21804|CElement::ReadDB|CRU|-1|** Read DB [active alarms]
2021/04/14 12:17:56.687|SLElement.exe|21804|CElement::LoadProtocol|CRU|-1|** Read Templates
2021/04/14 12:17:56.687|SLElement.exe|21804|ElementStarter::LoadDescriptionParameters|CRU|-1|** Loading parameters from description.xml.
2021/04/14 12:17:56.688|SLElement.exe|21804|ElementStarter::LoadProtocolParameters|CRU|-1|** Loading parameters from protocol’s xml.
2021/04/14 12:17:56.688|SLElement.exe|21804|ElementStarter::LoadControlProtocolParameters|CRU|-1|** Loading parameters from element control protocol.
2021/04/14 12:17:56.691|SLElement.exe|21804|CElement::LoadProtocol|CRU|-1|** Load relations
2021/04/14 12:17:56.691|SLElement.exe|21804|CElement::LoadRelations|INF|-1|Lock sequence(1) for PID -65132- is 65132,65139,65146
2021/04/14 12:17:56.691|SLElement.exe|21804|CElement::LoadRelations|INF|-1|Lock sequence(1) for PID -65146- is 65132,65139,65146
2021/04/14 12:17:56.691|SLElement.exe|21804|CElement::LoadRelations|INF|-1|Lock sequence(1) for PID -65049- is 65049,65054,65060,65068
2021/04/14 12:17:56.691|SLElement.exe|21804|CElement::LoadRelations|INF|-1|Lock sequence(1) for PID -65060- is 65049,65054,65060,65068
2021/04/14 12:17:56.691|SLElement.exe|21804|CElement::LoadRelations|INF|-1|Lock sequence(1) for PID -65054- is 65049,65054,65060,65068
2021/04/14 12:17:56.691|SLElement.exe|21804|CElement::LoadRelations|INF|-1|Lock sequence(1) for PID -65139- is 65132,65139,65146
2021/04/14 12:17:56.691|SLElement.exe|21804|CElement::LoadRelations|INF|-1|Lock sequence(1) for PID -65068- is 65049,65054,65060,65068
2021/04/14 12:17:56.691|SLElement.exe|21804|CElement::LoadProtocol|CRU|-1|** Load RCA Chains
2021/04/14 12:17:56.691|SLElement.exe|21804|CElement::RefreshPropertySourceInfo|CRU|-1|** Refreshing property source info
2021/04/14 12:17:56.691|SLElement.exe|21804|CElement::RefreshAllProcessingSequences|CRU|-1|** Refreshing all table column processing sequences
2021/04/14 12:17:56.692|SLElement.exe|21804|CElement::InitializeAdvancedNaming|CRU|-1|** Initializing Advanced Naming for all tables
2021/04/14 12:17:56.692|SLElement.exe|21804|CElement::LoadProtocol|CRU|-1|** Detect Export protocol information
2021/04/14 12:17:56.692|SLElement.exe|21804|CElement::LoadProtocol|CRU|-1|** Loading information
2021/04/14 12:17:56.692|SLElement.exe|21804|CElement::LoadProtocol|CRU|-1|** Detect topology
2021/04/14 12:17:56.692|SLElement.exe|21804|CElement::LoadProtocol|CRU|-1|** Destructing template
2021/04/14 12:17:56.692|SLElement.exe|21804|CElement::LoadProtocol|CRU|-1|** Destructing filtered template
2021/04/14 12:17:56.692|SLElement.exe|21804|CElement::LoadProtocol|CRU|-1|** Destructing trending
2021/04/14 12:17:56.692|SLElement.exe|21804|CElement::LoadProtocol|CRU|-1|** Destructing filtered trending
2021/04/14 12:17:56.692|SLElement.exe|21804|CElement::LoadProtocol|CRU|-1|** Destructed
2021/04/14 12:17:56.692|SLElement.exe|21804|CElement::Start2|CRU|-1|** Destructing alarm info
2021/04/14 12:17:56.692|SLElement.exe|21804|CElement::Start2|CRU|-1|** Destructed
2021/04/14 12:17:56.692|SLElement.exe|21804|CElement::StartFunc|CRU|-1|** Setting alarm count
2021/04/14 12:17:56.692|SLElement.exe|21804|CElement::StartFunc|CRU|-1|** Initializing alarm socket
2021/04/14 12:17:56.692|SLElement.exe|21804|CElement::StartFunc|CRU|-1|** Checking masked info
2021/04/14 12:17:56.718|SLElement.exe|21804|CElement::StartFunc|CRU|-1|** Setting trend info
2021/04/14 12:17:56.718|SLElement.exe|21804|CElement::StartFunc|CRU|-1|** Notifying connected elements
2021/04/14 12:17:56.718|SLElement.exe|21804|CElement::StartFunc|CRU|-1|** Start Complete
2021/04/14 12:17:56.721|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::StartFunc|CRU|-1|LoadProperties returnes. 0x00000000
2021/04/14 12:17:56.721|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::Start|CRU|-1|Initializing Port
2021/04/14 12:17:56.721|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::Start|CRU|-1|Starting Timers
2021/04/14 12:17:56.721|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::StartTimers|CRU|0|Starting protocol thread.
2021/04/14 12:17:56.721|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::Start|CRU|-1|Starting Protocol done
2021/04/14 12:17:56.722|SLLog|ApplyLogLevels|CRU|-1|Log Levels: Info: 0; Error: 0; Debug: 0 (custom)
2021/04/14 12:17:56.722|SLDataMiner.exe – aws_winserver_api|8592|CElement::Start|DBG|-1|Complete.
2021/04/14 12:17:56.722|SLDataMiner.exe – aws_winserver_api|8592|CElement::SetState|DBG|0|** Setting state from 1 to 10 (RealState = 4)
2021/04/14 12:17:56.722|SLProtocol – 1976 – aws_winserver_api|4296|CProtocol::ProtocolThreadFunc|CRU|0|[Aws cloudwatch api/1.0.0.1] aws_winserver_api – ProtocolThread
2021/04/14 12:17:56.722|SLDataMiner.exe – aws_winserver_api|8592|CElement::Activate|DBG|0|** Alarm template :
2021/04/14 12:17:56.722|SLProtocol – 1976 – aws_winserver_api|4296|CProtocol::ProtocolThreadFunc|DBG|0|– Waiting for Polling to be enabled.
2021/04/14 12:17:56.722|SLDataMiner.exe – aws_winserver_api|8592|CElement::Activate|DBG|0|** Trend template :
2021/04/14 12:17:56.722|SLDataMiner.exe – aws_winserver_api|8592|CElement::InitializeLock|DBG|0|** Initializing lock status
2021/04/14 12:17:56.723|SLProtocol – 1976 – aws_winserver_api|4296|CProtocol::ProtocolThreadFunc|DBG|0|– Polling enabled.
2021/04/14 12:17:56.749|SLDataMiner.exe – aws_winserver_api|8592|CElement::InitializeLock|DBG|0|** Not locked.
2021/04/14 12:17:56.749|SLDataMiner.exe – aws_winserver_api|8592|CElement::NotifyRedundancy|DBG|0|** Redundancy Changes
2021/04/14 12:17:56.749|SLDataMiner.exe – aws_winserver_api|8592|CElement::NotifyServiceTriggers|DBG|0|** Service Triggers
2021/04/14 12:17:56.750|SLElement.exe|21804|CElement::NotifyAlarmState|DBG|0|** Element Alarmstate changed to 0
2021/04/14 12:17:56.766|SLProtocol – 1976 – aws_winserver_api|15512|CManagedScript::Load|ERR|-1|Compilation failed for QAction 2
(44,136): error CS0103: The name ‘QActionID’ does not exist in the current context
2021/04/14 12:17:56.766|SLManagedScripting.exe|ManagedInterop|ERR|-1|10|No CodeBuilder found for cookie0
2021/04/14 12:17:56.766|SLProtocol – 1976 – aws_winserver_api|4296|CQAction::Run|ERR|-1|QAction [2] triggered by [pid=2/idx=-1/pk=/user=] failed. (0x80040221)
Input: new =
Input: old =
Input: extra =
2021/04/14 12:17:56.781|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::HandleAnotherTelnetClient|DBG|0|Telnet clients connected Primary = 1, Derived = 0
2021/04/14 12:18:09.421|SLProtocol – 1976 – aws_winserver_api|16828|CProtocol::HandleAnotherTelnetClient|DBG|0|Telnet clients disconnected
2021/04/14 12:28:43.237|SLProtocol – 1976 – aws_winserver_api|12048|CProtocol::HandleAnotherTelnetClient|DBG|0|Telnet clients connected Primary = 1, Derived = 0
2021/04/14 12:29:16.142|SLProtocol – 1976 – aws_winserver_api|12048|CProtocol::HandleAnotherTelnetClient|DBG|0|Telnet clients disconnected
Hi Roxana,
The following line in the logging points us to where things go wrong:
Can you please check in your code for a “QAction” XML tag, where the id= attribute has the value “Qaction_ID” and replace it by a valid unique integer.
Please note that if you have DataMiner Integration Studio (DIS) you can use the validate button in the upper left-hand corner to pinpoint these issues faster.
Show 2 more comments
