Element log issue in Dataminer
Solved1.66K views28th February 2023cefsharp issue log
7
Benjamin Hodžić [SLC] [DevOps Advocate]1.38K 28th February 2023 0 Comments
I tried to open an element log on a customer's DMA, and this pop-up showed:
My questions are:
  1. What could be the root cause of this?
  2. Why is CefSharp used in the Logs?
  3. What is the fix for this issue?
Benjamin Hodžić [SLC] [DevOps Advocate] Selected answer as best 28th February 2023
Simon Raine [SLC] [DevOps Member]2.08K Posted 28th February 2023 1 Comment
Sounds like your cube is running in a shared location. in this case, CefSharp is not downloaded automatically. It needs to be installed manually.
Benjamin Hodžić [SLC] [DevOps Advocate] Posted new comment 28th February 2023
Benjamin Hodžić [SLC] [DevOps Advocate] commented 28th February 2023
That was the case, indeed. The customer is informed and they will install the package.
