ElasticSearch Cluster Monitor – how to enable TLS?
Solved1.67K views30th January 2024elastisearch opensearch TLS
Piotr Borowski [DevOps Member]550 21st November 2023 1 Comment
I am trying to use the “Elastic ElasticSearch Cluster Monitor 1.0.1.6” protocol to monitor an Opensearch database,
DB only accepts secured connections, so TLS must be enabled.
how to properly configure element to enable TLS connections?
In general tab of the element I do not see way to enable TLS
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 30th January 2024
Piotr Borowski [DevOps Member] commented 23rd November 2023
It is working, It seems that the issue was elsewhere. So, the good news is that you can use the Elastic driver for monitoring OpenSearch, and you just need to enter https://dma-elasti.local/ or https://10.33.44.55 in the element IP field.
Thibault Heylen [SLC] [DevOps Member]1.51K Posted 23rd November 2023 0 Comments
Hi Piotr,
I would assume you need to install the certificate also on your DataMiner Server.
Can you share your solution? I’ll make sure it’s more clear in our documentation/help for other users then.
