EEG Lexi Automation Script For Encoders
Solved2.51K views14th July 2023automation scipt Lexi
David Rowell [DevOps Member]221 20th May 2022 1 Comment
I am trying to create an automation script for Lexi so that our operators can use the scheduler to schedule times the Lexi encoder automatically turns on. Is it possible to create the script this way so that it requires the operators to select the channel themselves when they schedule it or would that require a C# script? I wanted to create one script instead of 20-30.
Marieke Goethals [SLC] [DevOps Catalyst] commented 14th July 2023
As this question has been inactive for a long time, we will now close it. If you want further assistance, could you post a new question?
Miguel Obregon [SLC] [DevOps Catalyst]23.47K Posted 23rd May 2022 0 Comments
Hi David,
In this case you could use a script parameter to pass the display key of the table (in your example, the channel) to the set action. However, I noticed that (using a ‘set’ action) is not possible to pass the value of the script parameter to the index (the drop-down list in your image). I believe that the only option is to perform this action via C# script. The script should look like as follows:
The C# action:
 Script dummyElement = engine.GetDummy(“EEG Lexi”);
Script spChannel = engine.GetScriptParam(“channel”);
dummyElement.SetParameterByPrimaryKey(3002,spChannel.Value,”1″);
where:
  • 3002 is the parameter ID of the parameter ‘Switch State On (Instances)’
  • ‘1’ is the value that represents the value ‘On’. You can visualize this in the connector definition:
Hope it helps.
David Rowell [DevOps Member]221 Posted 24th May 2022 0 Comments
Hey Miguel,
Thank you so much for your answer. This has been very helpful. I attempted to test this and it keeps failing. Also, is it possible to have a drop down of channel names instead of having to manually enter the channel index?
David Rowell [DevOps Member] Edited answer 24th May 2022
