Edge Manager / Site Manager connection through dataminer.services?
Solved838 views13th May 2026Site Manager
Jörg Knesebeck [DevOps Enabler]434 13th May 2026 0 Comments
Hi Team,
while investigating Edge Manager / Site Manager function, following question came up for me:
On the help page About Edge Manager | DataMiner Docs it's mentioned that SiteManager DxM can only be deployed on DMAs connected to dataminer.services. Makes sense so far. I assume that the actual functioning of Site Manager also requires the DMA (on-prem, self-managed in my case) connected to dataminer.services, right? The dedicated tunnel always needs to route through dataminer.services?
Thanks,
Jörg
Jörg Knesebeck [DevOps Enabler] Selected answer as best 13th May 2026
Jan-Klaas Kesteloot [SLC] [DevOps Advocate]1.65K Posted 13th May 2026 1 Comment
Hi Jörg,
Thanks for reaching out. Your assumption is correct.
The functioning requires the DataMiner System to be connected to dataminer.services . This is because the secure communication tunnels set up by Edge Manager indeed route through dataminer.services.
Jörg Knesebeck [DevOps Enabler] commented 13th May 2026
Hi Jan-Klaas, alright, many thanks for confirming!
